HOW TO SIZE A COMMON CHILLED WATER PIPE FROM A HEADER
How do i get to size common chilled water pipes(Supply & Return Pipes) from a header?
Assuming 100mmdia. chilled water pipes come out of the two chillers then a header connects them together to form a common chilled water pipes(Supply & Return Pipes)
Below are the following parameters considered:
Chiller Capacity: 291kW (2nos)
Location: On roof terrace to serve second floor to Ground floor. Building Height: 12metres
Effective Chilled Water Pipe Horizontally for each floor: 135metres
