Default Properties and Design Tables
I want to have SW automatically add properties and a design table to each new part/assembly. (materials, drawnby, description...)
I have been googling around trying to find example files for the syntax required.
Can someone post their properties.txt and a designtable.xls for what they use?
RE: Default Properties and Design Tables
Consider using the Property Tab Builder for property propagation.
Use the Auto-create option when creating a DT.
dedevo,
   You can systematically add the design table by adding one to your prototype file(s).
               JHG
