Difference between API 610 & ANSI B73.1 Crude oil transfer pump.
Hello Everybody,
What is technical Difference between API 610 and ANSI B73.1 Crude oil transfer pump? I understand API 610 pumps are more costly compare to ANSI B73.1 pump.
Can we add ANSI B73.1 in crude oil refinery system where other pumps are API610? Which factors should we consider for this installation? Please find attached document.
