Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Where have you been all my life! I found the answer I needed in seconds..."
Geography
schnell (Electrical)
11 Jan 11 6:54
I have some data points that form a curve.
I wish to put the points into excel and get it to  put an equation to the line.
Do you know what is th name of the Excel math software feature that does this...so that i can install it.
Also, do you know how i can go about this?
Onda (Marine/Ocean)
11 Jan 11 7:48
I usually use this software:
http://www.cadreanalytic.com/Regress.htm
it is free and is better than Excel.
Onda
MintJulep (Mechanical)
11 Jan 11 7:52
If you plot the points on an Excel chart you can use the "Add Trend Line" feature to display the equation on the chart.
If you just want the coefficients you can use the LINEST() or LOGEST() functions.  They are array functions, so read help carefully.
corus (Mechanical)
11 Jan 11 8:24
I use CurveExpert 1.4. It's also free.
Tata but not yet tara
11 Jan 11 11:04
w tried excel and cadreanalytic and bith didn't work when we selected cubic polynomial.
Excel showed us a graph that was a near perfect fit............it also gave us the equation....but when we plotted it ourselves it did not agree with the excel function.
-do you know  what we can do?
(our  data points were almost a straight line but with a bit of a wiggle , so we tried cubic.)
Onda (Marine/Ocean)
11 Jan 11 12:04
The problem of excel is that don't show you all significant digit of the formula. So you can see a very good fitting curve but when you try to replicate it doesn't work.
I don't know why regress don't work for you.
I've used a lot with always good result.
corus (Mechanical)
11 Jan 11 13:01
You can change the format of the printed equation so it has more decimal places or scientific notation. That should give you a better fit.
Onda (Marine/Ocean)
11 Jan 11 13:03
How to change the format of printed equation?
thanks
Onda (Marine/Ocean)
11 Jan 11 13:11
I've found. Right click on the equation and change the format.
thanks anyway.
IDS (Civil/Environmental)
11 Jan 11 20:42
The Excel help gives the formula below for fitting a cubic curve to a set of x,y data:
=LINEST(yvalues, xvalues^COLUMN($A:$C))
I prefer:
=LINEST(yvalues, xvalues^{1,2,3})  (note curly brackets)
but they give the same answer, and the same as the trend line in a chart for the same data.
To get all 4 coefficients enter the formula as shown, select the cell with the formula and the adjacent three cells to the right, press F2, then ctrl-shift-enter.
You can also use the INDEX() function to return a coefficient other than the first one as a single value. e.g.:
=INDEX(LINEST(yvalues,xvalues^{1,2,3}),2)
to return the coefficient for x^2
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
12 Jan 11 4:28
These are the Excel graphs.....
http://i51.tinypic.com/1y0ht0.jpg
....thin black line = from our data.
....thick black line is what excel plotted
....pink line is our plot of the equation that excel
    claims  represents  the thick black line
(as you can see, the thick black line and pink lines don't match.)
Our data is as follows......
X       Y
820    1036
755    904
715    851
696    818
644    748
501    528
370    370
12 Jan 11 4:57
OK thanks Corus and Onda and all other repliers..
we did the decimal place thing on the formula and its ok now.
thankyou to all.
Onda (Marine/Ocean)
12 Jan 11 5:13
With normal precision (4 digits) I've the same problem but if I increase the precision of the formula to 8 digit my plot of the equation exactly match the excel plot of interpolation.
It's just a problem of digits!!
12 Jan 11 6:11
Results from Linest attached. (see edit box for the formula)
Doug Jenkins
corus (Mechanical)
12 Jan 11 9:49
Out of interest, CurveExpert gives the much simpler fit to the data for a Saturation Growth-Rate Model: y=ax/(b+x) with
a =    -2.18445071972E+003
b =    -2.55488142333E+003
BigInch (Petroleum)
17 Jan 11 8:34
Looks like this reference works here too,
http://www.eng-tips.com/viewthread.cfm?qid=214997&page=1
Close Box
Join Eng-Tips® Today!
Join Us             Close
