Galvanising machined components
Hi
I have a few small mild steel machined components which I need to get galvanised as the customer has requested it . They are going under water in a sewage treatment works so i assume this is the best treatment .
My question is some of the parts have threads and bore diameters which i wouldnt want coating . Is there a way of putting something on them so the galvanise dosen't stick etc .
I thought about screwing bolts into the threads & fitting shafts in the bores and removing afterwards , but wasn't sure how easy they would be to remove and if the galvanise might chip when taking them out etc .
Any suggestions welcome
Cheers
chris
Cheers
chris
RE: Galvanising machined components
Not sure about how to prevent the galvanize process from bonding to the threads. What does your vendor recommend?
Petrotrim Services
