UG/Open trouble...
UG/Open trouble...
hello... can anybody help me with the ug-open macros? i do not mean
thos open++ api's. after weeks of trouble i finally switched to ug-open
in c++ and yes, i can compile and run it but if i try to do something more
advanced like printing out the number of loaded parts, it didn't work...
why does UF_PART_ask_num_parts always resond with 0 (zero)???
UG is running and i loaded an example assembly with dozens of parts
so this call should at least give out something else than just zero.
i didn't get it, even UF_initialize and UF_terminate are working fine...
can anybody help me with this or give me *tested* working examples?
thank you very much
thank you very much
