COSMOS/M installation - Windows 7
I have a permanent cosmos/m license I've use for 5 years w/ Windows XP w/ dongle. Tried to install on new Windows 7, 64 bit machine. New machine recognizes dongle, but not licence file. Any tips?
RE: COSMOS/M installation - Windows 7
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
TOP
CSWP, BSSE
Try to install it there.
Sorry to hear that SW isn't willing to help, makes you think about the company....
I get GeoStar to run fine though on W7 x64. Maybe update the driver for the dongle..
TOP
CSWP, BSSE
I have found a way to use Cosmos/M and Windows Seven in the same time. I have used VmWare Workstation, a virtual machine software, to install an virtual xp, and it works. I just have finished a static analysis for test, it gave me no problems.
TOP
CSWP, BSSE
TOP
CSWP, BSSE
TOP
CSWP, BSSE
- Parallel port
- Sentinel/Rainbow license server
- Software Installation
Parallel Port- Newer machines don't have parallel ports so a PCI/e or PCI card needs to be installed and gotten to work
- 3rd party parallel ports can be tricky to get working. In my case with a 64 bit Phenom motherboard and an Oxford parallel port a manual install of the port was required.
- You might need to have a parallel port printer handy to check the port function before you install the dongle.
- Frequently the port with a PCI install will be named LPT3. Using device manager make it LPT1 just for consitency.
- Once the parallel port is working install the dongle
Rainbow Sentinel License Server- Goto Rainbow Support for the SuperPro dongle
- Download the latest driver and SuperPro Medic
- SSDCleanup is also helpful if you need to uninstall previous drivers
- Install the Sentinel Protection Server
- Install SuperproMedic and check that the driver and dongle are visibile and working
- Fix problems if they occur
Install Cosmos/M- Install in the usual way. It should install as a 32 bit app
- Use the license administration tool to check that your license is working as intended
Caveat EmptorYour milage may vary. This is what worked for me and I haven't exercised all of Geostar yet. I'll be benchmarking soon. If you find something different works for you then please post in this thread and I'll make an FAQ out of it once it seems to be stable.
TOP
CSWP, BSSE
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
