NPT pipe threads
NPT pipe threads
NPT pipe threads
I am looking for a torque spec for sealing 1\2" Npt threads.
RE: NPT pipe threads
Hmmm... Torque values would likely be very dependant upon what kind of thread lubricant you are using.  I have a copy of IPT's Industrial Fasteners Handbook, and they recommend for sizes 1" and under, NPT joints should be hand tightened 3 or 4 turns and then tightened by a wrench for 3 turns.  Specifically for NPS 1/2", they recommend 7-1/2 turns.
One major caution that they mention is that a joint that is made-up too quickly will generate a lot of heat due to friction.  A joint that is pressure tight immediately after assembly may leak once it has cooled...
Hope that helps.
To add to reichertc's info, API provides the following for LP threads (which are essentially the same as NPT).
2" and below 3 turns past hand tight
2-1/2" and above 2 turns past hand tight.
