Valve Train Design
Valve Train Design
Hi!
I want to know where I can find a procedure to design a valve train (for gas, steam, oil, water, etc) taking into account pressure drops, etc etc. I have the main data from fluids (flow, temperature, pressure inlet, etc) and depending from use and application of each fluid, i can go to any CODE to choose valves and instruments. The only problem I have is to determine pressure drops due to valves, instruments, bypasses, and pipe lengths between valves and instruments.
Can you help me with that?
Thanks!
Saver
Thanks!
Saver
RE: Valve Train Design
Cheers.
K
