Solidworks compatability with Solid Edge?
Hello all,
Just wondering if there is any compatability between SW and SE?  I have a small project that requires the work to be done in Solid Edge so I was wondering if the work could be done in SW and then converted to SE somehow?  Suggestions Welcome, and thanks.
PD
RE: Solidworks compatability with Solid Edge?
The work can be converted in such a way that the SolidWedge users will be able to open it... but they won't be able to edit it as a native file.  The files will need to be exported in a neutral format like parasolid, iges, stp etc and imported into SE.
-Dustin
Professional Engineer
Pretty good with SolidWorks
If the work is required to be done in Solid Edge I guess it's because they want to be able to use the models? If so There is no shortcut except working with SolidEdge. Unless they can get away with Synchronous Technology for small modification I strongly suggest using SE.
Patrick
Are drawings involved?
The killer with any translation I've ever seen is that the links between models and drawings get broken so that the drawings are no longer associative.
I'd suggest asking the contracting agency if what you propose is acceptable.
I'd be big time PO'd if I'd paid for a Solid Edge pack and someone gave me a converted SW pack, but maybe that's just me.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
OK, thanks for the input!
