NX6 Move command
NX6 Move command
I am trying to copy a line around a circle, similar to a clock. I am using these lines as a reference as I lay something out. I am simply try to get 32 lines equally spaced around 360 degrees.
I have wasted lots of time on such a simple command, and I can't figure out how to do it.
Just under where the vector and axis point are specified is "Angle".
Is this the angle between the lines?
What is distance/angle divisions?
It can only be a whole number and not zero.
I recently got a new computer and whoever loaded it up for me forgot to put the documentation, so I am currently unable to look this up.
RE: NX6 Move command
Insert -> Associative Copy -> Instance Geometry...
...and choose Type 'Rotate', select your original line segement, select the axis and origin of the 'circle', under 'Angle' enter 360/32 and under 'Number of Copies' enter 31, and then hit OK (as per the attached example)?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
