90 degree V-notch
90 degree V-notch
90 degree V-notch
Doing a sheet metal pan using Wildfire 5. The angle of the current V-notch for the corner relief is 74 degrees, but we need it to be 90 degrees to be able to punch it with the turret punch. Is there a way to change the angle? Or another way to add automated 90 degrees v-Notch?
Right now we have to unbend, then sketch the cut, then rebend....which is time consuming.
RE: 90 degree V-notch
Anyone have any tips??
Post some pictures of what you are trying to do, your question is unclear.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
I find out that the v-notch angle is related to the corner gap. But I want to make the v-notch always 90 degrees so I can cut it with a square punch.
Here is the pan
 and here is the v-notch
How do you plan to cut a 90deg V out of a 90deg corner?
*Slap* Yeah that doesn't work too well does it, lol.
Ok disregard this question.
