Shakedown of structures
Hello all,
I know that if a material is loaded beyond its yeild strength then shakedown theory can be applied to studying the material behaviour under cyclic loading.For materials in contact if the sub surface stress does not reach yeild, however, the surface asperities undergo plastic deformation under contact then can Shakedown theory still apply in this case.Thanks
