How to create a Terminal lug model
I'm working in France on NX 6 since 2 months (I finished my studies in June 2010, and just been learning Catia V5).
I'd like to draw a terminal lug, but I don't know how to do a shape (check the attached file).
Could someone explain me the procedure please ?
Thnak you,
Matthew
Thnak you,
Matthew
RE: How to create a Terminal lug model
Best regards,
Michaël.
NX4+TC9 / NX6+TC8Unified / NX7.5 native
Best regards,
Michaël.
I'm meeting a problem when I use the "through curve mesh".
When I select the first curve, all the circle is selected, whereas I imagine juste a quart is needed. Does the problem come from wrong intersection curve ?
thanks for you all.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
first, I can't fill the curve (I think we don't have the licence to use the N-sided command ...).
And I tryed with the "through curves", but my lug is assymetric; the results is "strange": there is a sort of helix angle.
1. just extrude closed contour with the height 0 ("zero").
or
2. use bounded plane option (Insert->surface->bounded plane).
I prefer to use first option (extrude with zero height).
Maybey there are to much features but i got a fairly good result i think.
The trick is to create some extra geometry, the splines, which are tangent to both solids and when creating the through curve mesh also link the sheet tangent (G1) to the solids.
Best regards,
Michaël.
try using proper aligment method. in your case (as John did) you have to use aligment by points, and manualy defint these points. Actually I usually use through curve mesh option, because in some cases aligment by points is pain in the head...
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX7.5 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
And eex23's correct in that by using the alignment options you have control over the so-called 'twist' of the results as you transition from one profile to another, even if they have a different number and/or shape of segments.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thanks for you all, it helps me understanding the differents tools of the program, and not just apply a procedure ^^
