Standards for Ground reel
As per the standards what is the size of the copper cable in ground reel for grouding the Trucks.
thanks
RE: Standards for Ground reel
If the grounding cable is only for static electricity discharge I think 2 AWG [35 sqr.mm] is fair enough.
If it is used to protect the truck from direct contact with live conductor 2/0[70 sqr.mm] will be recommended.
In any case the connection to ground has to be tested on line.
See" Utility Ground Reels"[for instance]:
http://www.hannay.com/pages/downloads/sgcr.pdf
