Steel Shutter for Concrete
Can anybody point me in the direction of how to design a 15m diameter shutter from steel for a concrete pour. The shutter is going to be 3 rings of 152UC curved and bolted together and then 6mm infill plate. I can design the plate from lateral pressures but how does one quickly calculate the radial force in the UC's. The shutter is only 1.7m high with a ring of UC's on the ground, one at mid height and one at the top. The shutter is completely above ground level.
RE: Steel Shutter for Concrete
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
yes the shutter is the formwork for the concrete. Like a large steel mould I suppose.
