ARV for HDPE pipe.
ARV for HDPE pipe.
ARV for HDPE pipe.
A 2" ARV needs to be attached to a 30" HDPE force main at the high point. Is there a particular type of ARV that I should use? Is there any specs available for this application? Thanks very much for your time.
RE: ARV for HDPE pipe.
go to www.ventomat.com for the best technical information and software on air valves. 2" looks a little small on 30" line though.
Thanks for the reply. I actually contacted vent-o-mat and was told 2" ARV will be sufficient for our design purpose which is just to get rid of air pocket in the sewage, if there will be any.
