Sketches: Relationships between 2 sketches
I am trying to create an organic assembly by sketching and then adding in driven parts.
So far I have two sketches - one in one plane and another in a perpendicular plane. If I enter the sketch mode for the second sketch and attempt to create an endpoint relationship, it finds the endpoint of the line I desire but does not find any endpoints on my first sketch (except some apparently arbitrary points which seem irrelevant).
If I attempt to create endpoint relationships in the sketch mode of the first sketch, it finds the endpoints but doesn't find anything to do with the second sketch.
I am certainly not a pro user so any and all help will be appreciated!
RE: Sketches: Relationships between 2 sketches
For the first point, have you got end point location on in Intellisketch?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
