Modeling a Center Tapped Delta Generator in SKM
Does anyone know how to model a Center Tapped Delta connected generator in SKM. Generator is a 240V L-L with 120V L-N and 208V 3rd leg to neutral. I only see an option to pick an ungrounded Delta generator when specifing a delta generator in SKM
If the center tap is grounded I would not think this will have any effect on the 3phase short circuit current but rather will have an impact on the L-G or zero sequence fault current. I'm not 100% sure yet if this center tap will be grounded so it may be a moot point but I'd still like to know how to model for future reference.
RE: Modeling a Center Tapped Delta Generator in SKM
