part winding starters in 460 volts
Hi Guys , ..does somebody knows if it is possible to start a 460 volts 3 phase electric motor with a part winding starter ??? per my knowledge you can only start in low voltage ( 230 v )..
my motor has 12 leads ..
RE: part winding starters in 460 volts
12 lead motors usually provide Y-Delta starting and dual voltage connections. Some however are built to allow Part Winding start and sacrifice the dual voltage option, common in motors that are too large to be run in a lower voltage anyway. Weg does it that way that I know of.
http
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
thanks for your support...
Muthu
www.edison.co.in
htt
Muthu
www.edison.co.in
