Dimensions Double in Drafting
When I started up my station today and dimensioned a print, all of the values were doubled and one dim line is snapped to the part and the other is off in the distance. This has never happened before, but all dimensions are now doubled and one dim line is off the part. Any suggestions?
RE: Dimensions Double in Drafting
The dim should read 24.05 and have 2 arrowheads of course. None of can figure out why its doing this ugh!
delete the old dimension. Create a new dimension, but before you click the location, right-click and turn off the HALF DIMENSION option.
Once you turn it off, all new dimensions will be normal.
