VisualBasic .NET question
Dear All,
What kind of vb routine could I use to ask What is the highlighted NXObject?
RE: VisualBasic .NET question
1. GET ALL PRE-SELECTED OBJECTS
Dim num_selected As Integer = sel.GetNumSelectedObjects()
2. PUT THOSE OBJECTS IN AN ARRAY
Dim objArray(-1) As NXObject
For inx = 0 To num_selected - 1
   ReDim Preserve objArray(inx)
   objArray(inx) = sel.GetSelectedObject(inx)
Next
daluigi,
Thanks a lot.
And how could I remove this preselected object from the selection list.
I try the theUI.SelectionManager.RemoveFromSelectionList() function. But I can't add any value to the selectionhandle.
1. REMOVE OBJECT FROM THE LIST
Redim objArray(-1)
2. DE-SELECT THE OBJECTS ON SCREEN
Dim partCleanup1 As PartCleanup
    partCleanup1 = s.NewPartCleanup()
    partCleanup1.TurnOffHighlighting = True
    partCleanup1.DoCleanup()
    partCleanup1.Dispose()
Thanks,very thanks.
Your method works on the graphics area, it is very good.
But the component remains selected in the assembly navigator tree.
I tried the Part cleanup utility and I found that it can remove the selection from the component in the ANT, too.
But when I recorded the part cleanup utility and rerun the journal it doesn't work in the ANT. The component remained seletected.
what could I do?
Hi All,
is there any vb.net macro available to select
the components of same type(eg ejector pins, tap holes etc),
or is there a way to write in either Grip/KF.
about an year ago we switched to NX in our design dept
and we are experiencing some issues with the models sent to
shop floor like missing holes etc.
Girish.
