Y/C (S-video) to Composite conversion
(This question really is for work.)
We have to interface several Y/C (or "S-video") video signals to a monitor that has Composite inputs. So I'm in the market for off-the-shelf, professional-grade, S-video to Composite video converters. For NTSC (North American) video.
The market appears to be swamped with cheap adapters that use the ol' capacitor trick. There are a few products that use proper active mixers, but those that I've found still do not include a luma trap (for notching out 3.58MHz from the luma signal before mixing, to avoid introducing colour artifacts). I'm looking for something better.
Can anyone point me towards any S-video to Composite video converters that actually do it correctly? With a luma trap to keep the colour stable, and with active circuitry to ensure that the output waveform is as correct as it can be.
I've already burned-up Google for a few hours. Perhaps I'm missing a critical keyword.
Thanks.
Thanks.
RE: Y/C (S-video) to Composite conversion
http://www.uzebox.org/wiki/index.php?title=FAQ
http://w
Maybe not full products, but may point you to some...
Dan - Owner
http://www.Hi-TecDesigns.com
However (don't know how many you need), there are a number of VCRs that can do this, which of course bring you into the fleabay market...
Benta.
"...converts a composite video or s-Video input through a digital comb filter to a composite and s-Video (Y/C) or component (YUV/RGB) video output."
http://www
Dan - Owner
Benta.
