Ethanol and Water Mixing
Q.1 - Which is the best method to mix water with Ethanol?
RE: Ethanol and Water Mixing
Ethanol is 100% mixable with water so just put them in the same tank?  or maybe in your stomach just make sure it's not denatured!
"Shaken, not stirred!"
Good luck,
Latexman
If you are working with pure ethanol then it is an easy task - circulating the tank with a pump-around or agitating with a paddle will quickly get the mixture homogeneous.
But if you are blending potable spirits it is a different matter.  Never add the whisky (or whiskey, depending where you live) to the water - always add the water to the whisky.  And never mix them while hot.  Both of these mistakes will result in a cloudy blend.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
The reason for adding alcohol first to a drink glass is that alcohol is lower density than water or other ingredients. If you add it last, it will float without mixing unless stirred (or shaken). If you add it first it will mix much better. Do not just pour the additives in one spot or they will channel to the bottom of the glass as the alcohol floats up. Pour around the surface. Ice in the glass helps when mixing this way. Professional bartenders rarely stir drinks.
Thanks all,
Actually just inline  mixing is not providing us homogeneous mixture, and also we want to mix during loading the truck.
latex, best answer yet.
mine is "dry, very dry"
Latex ... best answer on this forum today .. he he.
Yeah density plays an important part so yeah in a glass pour the alcohol first.
Ever considered a mixing tank before the truck loaders; you can generate vortex using baffles in the tank and/or an agitator if a batch process???
to add to the humor ... lots and lots of speed bumps for the truck.
S Mehta
By inline mixing I assume you mean you simply pump the water and alcohol into the same line.
Not good enough, I recall reading a report on a water line which carried water from two different sources, identifiable through analysis, and they found the two streams were flowing as separate parralel streams in the pipe for some considerable distance.
You have two low viscosity fluids here so adding a static mixer into the line wouldn't create too big a headloss penalty. Search for static mixers or Vortab, Chemineer, etc.
JMW
www.ViscoAnalyser.com
