Stopping Sight Distance
It is noticed in the newest version of AASHTO (highways) that the vertical curve length calculated from the SSD (stopping sight distance) is modified relative to that of the previous version; however, this modification is to the worse not to the better.
So, in the newest version (pages 271,272), Length L is calculated as AS2/658(when S is less than L) compared to AS2/404 in the 1994 version. The difference between the 2 results is mainly due to the change in the object height from 15 cm in 1994 to 60 cm in the new version. Hence by decreasing L the design speed on the highway is reduced and consequently reduction in quality of the highway.
So what do you think about that. Any interpretations are welcome.
Regards...
Regards...
RE: Stopping Sight Distance
