SW2011 crashes on material changes
Hello Group,
Solidworks 2011 crashes when I try to change the material appearance of a model. This occurs on all models. All modeling features behave well except for this issue. The dialog box says "Solidworks has stopped working...finding a solution to this problem. This may take several minutes". When I click 'ok', the program closes.
My computer is two months old and is an:
Intel i7, 12Gb RAM, 950 @ 3.07 Ghz
NVIDIA Quadro 2000
Anyone have thoughts on this? Thanks in advance.
Rich
NVIDIA Quadro 2000
Rich
RE: SW2011 crashes on material changes
2) Run a repair of SW
Also, you might want to check the kb to see if it's known issue. If it's not, and neither of CBL's suggestion work, you'll probably want to get your VAR involved.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
