Thermodynamic tables for internal combustion engine fluids
Hello
I have the charts of thermodynamic properties of fluids encountered in calculations of internal combustion engine cycles,but i want tables instead of charts.
i mean complete tables that include the parameters like
"internal energy,pressure,volume,entropy,temperature"for different
"Fraction of theoretical fuel".F=0.8,1.0,1.2
i want the tables like the charts that was reported
by N.A.C.A in 1943.(NACA RB 3G28)
Thank you
RE: Thermodynamic tables for internal combustion engine fluids
ok, what fuel & composition are you wanting the table data for?
it seems your best course of action is to contact N.A.C.A and ask them for the tabular data, since they developed the charts.
good luck!
-pmover
Make your own tables form the charts. It may take a little bit of time but it should be worth it in the long run.
I want it for Gasoline-Air  Mixture (C6H16),and air with theoretical fuel"(CH2)x" in chemical equilibrium.
Thank you for your answers pmover & chicopee.
Have you poked around the NIST website (www.nist.gov) to see if you can find the information?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
