Looking for a high temp Rubber
Can somebody please help?  I need a high temp rubber for a laminaiton press pad.  I am looking for something that handle temps in the 675-700 F (357-370 C) range.  If you know of a material great... if you know of a supplier awesome!
Thanks!
RE: Looking for a high temp Rubber
Not likely you will find a rubber for that temp. How about thin sheet metal with some air pressure, or glass felt, or oil behind it.
I found Kapton which can go up to 725 but you will have to decide if it will work in your application.
Bill
