Problem with curve plotting in Abaqus
Problem:
a contactproblem between two bodies.
After plotting cpress the curves oscillates.
I think it has sth. to do with the meshing.
with normal meshing the curve looks smooth. But with more finer meshing it looses the smothness.
How can I fix this problem in Abaqus (CAE) ?
many thnax
many thnax
RE: Problem with curve plotting in Abaqus
You can always use filter to make a curve smooth.
In Abaqus/Viewer you can operate on xy data, one of the operations are SAE filters.
Barten
1. Switch to surface to surface contact
2. Make 2 copies of the contact with the master slave reversed on 1
I hope this helps.
Rob Stupplebeen
I have already switched to surface to surface.
the smooth function helps, but if the smooth-factor is very small, e.g. 0.01 the max. value gets smaller because of the
smooth-function.
