gas turbine compressor map charactheristic with IGV
I am developing a mathematical model that simulates a combined cycle in off design conditions following the beta lines concept. I got a compressor map  which shows me a complete behavior of a wide range operation profile , but I aim to analysing  the possibility to consider a IGV operating in order to simulate a constant flue gas temperature (to a certain load ), most know as TIT, pushing down the air mass flow through the gas turbine. How should  like the corrected speed lines according to the openess level in control valves(dampers) in front of the compressor intake , moreover, how should be the pressure ratio based ont this new corrected speed. ?? I would appreciate if some one could forwrad me a typical compressor map with those features available?
RE: gas turbine compressor map charactheristic with IGV
What are an IGV and a TIT as used in your post?
Is this for a work or school assignment?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
IGV - Inlet Guide Vane
TIT - Turbine Inlet Temperature
Sounds like ABB/ALSTOM
GTstartup,
You are right. Both acronyms are correct but they are used for any gt manufacturer. To be more precise, IGV has the main purpose to control air mass flow flowing through the compressor, keeping the TIT (the temperature measured just before the first  row of blades in the expansion zone, or at combustion chamber outlet) as righ as possible, or in other words, searching for the highest possible thermal efficiency at a certain part load operation.
You need to be a little more specific with your request.  Will your CCGT be based on a constant speed frame type machine or a variable speed aeroderivitave type CT.  IGV's can be used for different purposes.  You use flue gas temperature and TIT in the same sentence almost in a synonymous sense.  When I think of TIT, it is products of combustion leaving the combustors entering the first stage nozzles, and when I think of flue gas, I think of what is coming out the back end of either the turbine or more likely the discharge of the HRSG string.
rmw
rmw,
Yes, you are right. I posted my request with a lack of information. My model is based on a single shaft machine running at constant speed lines. I went through the Flether's book (GT Performance) but there are few tips regarding to IGVs behavior. As I understand  the constant speed lines move  horizontally to the left,at most but I didn't see any  one showing this behavior.
thanks anyway
