Material properties
Material properties
Material properties
Hi, I´ve some problem with defining Young´s modul for classic solder (SnPb)...I´ve found that it should be about 30GPa, but in all APDL files which is dealing with this problem I´ve found about 60000...
Please can somebody help?Thanks a lot!
RE: Material properties
Check your units...
If you mean in ANSYS, it should be normal SI system...so for Young´s modulus it´s Pascal...
Depends on the unit system you have specified and also the unit system specified in the examples you are looking at.
Make sure all your units are compatible
Thanks for reply. I hope I´ve figured it out.
So what was the problem....?
I think,that they used a uMKS units instead of SI.
