Calculation of Stresses without temperature and external load
I am trying to calculate stresses and strains in the thin film deposited on substrate by ABAQUS.
How can I calculate stresses and strains while keeping the temperature of the body constant and under zero external load?
I am getting results by varying the temperature but not when the temperature is constant.
Thanks in advance
Waiting for reply
Thanks in advance
Waiting for reply
RE: Calculation of Stresses without temperature and external load
Tata but not yet tara
thanks in advance and waiting for reply
Thanks for the reply but how can I simulate this with ABAQUS?
And also could you please tell me that how can I get coherency strain energy due to the difference in the coating and substrate material properties like lattice parameters, young's modulus, poison's ratio, coefficient of thermal expansion without external load and with constant temperature(e.g.500 degree C)?
And is it possible to give lattice parameters values in ABAQUS? if yes, how because I was not able.
A research article is attached in which I have highlighted the portion where the author mentioned about the calculation of strain using lattice parameters.
Thanks in advance
Waiting for the reply
Thanks for the suggestion but I have already written to the author and there is no response thatswhy I am here to get some help.
I recently started working with ABAQUS and not a expert like you.
So, if you can help me regarding this, it will be appreciable.
Thanks in advance
