NXOpen.net Read Expressions
Hi, I'm using NX7.5 and Visual Studio 2010.  I'm trying to read the numerical value of an expression (e.g 20mm) and display this in a text box in my visual basic program.  This is the code I have so far which was created using the NX Journal feature.
Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        'Load default values
        Dim workPart As Part = theSession.Parts.Work
        Dim displayPart As Part = theSession.Parts.Display
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Expression")
        Dim expression1 As Expression = CType(workPart.Expressions.FindObject("dblRawMaterialWidth"), Expression)
This is finding a dimension which I have called 'dblRawMaterialWidth' but I now want to read the value of this and display it in a text box on my form.  Any ideas?
Many Thanks,
Ben
RE: NXOpen.net Read Expressions
Eventually got there after many hours!
Just needed this simple line:
txtChangeMaterialWidth.Text = expression1.Value.ToString
Where txtchangematerialwidth is the name of the text box
