Looking for a better Solidworks Toolbox?
I'm running Solidworks 2010 and one of the things I
really don't like is the included Toolbox. I find it's
lacking a lot of hardware that I often use in my
assemblies (bolts, nuts, washers, etc.). Plus each and
every time I need to modify the length of say a bolt it
makes a copy of the bolt, etc.
What would even be better is to have a toolbox that can
corespond to parts numbers from say McMaster Carr or some
other online parts supplier.. so that when I add toolbox
hardware into my assemblies it will also link to the part
number from a site like McMasterCarr to facilitate easy
ordering.
Is anything like this possible? what 3rd party toolboxes
are available?
ordering.
are available?
RE: Looking for a better Solidworks Toolbox?
We use the Toolbox extensively for its fasteners. One of the best things we did was to have an intern go through our parts list and setup TB with our fasteners (P/N and descriptions matching our ERP).
On rare occassions we have found that our hardware was a different dimension than the Toolbox part. When we do learn of this we simply edit the definition in TB and it even corrects those parts already in use.
We have our system set to create a new part for each instance as this turned out to be much faster than the alternative of letting TB create new configs. Once a particular fastener is called for its part file is referenced if it already exists or a new part is generated if this is the first time it has been referenced. TB does not make multiple instances of identical part files.
What fasteners are you using that aren't in TB? Its library is quite extensive.
- - -Updraft
It is not difficult to model your own fasteners. That way, you get the level of detail you want in your model, and you get the BOM entry you want. You ought to be able to generate a purchase requisition by copying from SolidWorks and pasting.
Make sure all your screws and nuts are copied from the same root model. This way, you can replace pan head screws with cap screws or hex bolts.
Attach specification documents to your CAD models, and check the whole thing into PDM. Now, you can write ECRs on your fastener specifications.
This all is a fair bit of work, but you should do it only once.
I guess nobody sells a toolbox add-in or at least a custom toolbox directory that has standard hardware along with McMaster Carr part numbers on it?
Add new fasteners as they come up.
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
To take it another step further you can completly break the link to toolbox by using the sldsetprop.exe feature to change the icon from a bolt to the standard SW part icon. This way even when you upgrade your toolbox to a newer release it will not recognize th items you are already using as toolbox parts.
Hope this helps,
PD
The DB that does come with SW can be expanded to any size requirement you need. If the 1/4-20 SCHS is not your common fastener, but a 2" one is, then you can make a custom database and you can specify the size.
As for it making a copy of the part is because of an option that is setup in your Toolbox database. If you have it setup as a multi-user TB and the files are located at the server that everyone can access. Then I would use the option to change the master part file. I never had any issues with that.
This sounds to me more of a settings issue and the lack of knowledge about the Toolbox, from you initial post.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
www.scottjbaugh.com
Try 123GO (free) from http://www.logopress3.com/en/products-6.php
Their library is created using standard SolidWorks parts with design tables.
It's the easiest to customize and does not depend on any add-ins or other interface gadgets to learn or troubleshoot.
Certified SolidWorks Professional
www.scottjbaugh.com
http://www
