Excessive wear on nozzles
I am getting excessive wear and build up on my nozzles. Mostly when cutting 11Ga SS. If anyone can help with suggestions I would appriciate it.
RE: Excessive wear on nozzles
As far as build up, is the Stainless you're processing PVC Coated (Plastic Vinyl Coated)? Does your machine have a nozzle cleaning function you can enable or include in your NC Program (subroutine)?
Can you spray some anti-spatter agent on top of the material to prevent the build-up after piercing from sticking to the nozzle?
If you are cutting gauge material (22 GA to 10 GA or 0.030" to 0.135") I would use a nozzle gap of 0.020" to 0.030" since the diameter of the nozzle is 2mm at around 8-10 bars.
Keep in mind that nozzles are consumables and they wear out as I explained on my earlier post because you're cutting with high pressure gas and they sit closer to the material. Which machine are you using by the way?
I have also used our bulk N2 tank, it produces a britter edge but still chews up nozzles. I don't have this problem on any other material or thickness. It seems isolated to the 11 ga cut condition.
I will move the nozzle gap up to .020-.030 and see if it gets any better.
