Two Tubeside Fluids in Shell and Tube Exchanger
My Friends,
We are replacing a condenser (uses cooling water) which is nearing end of life, and also wanting to do some heat recovery into a process stream. Rather than buy two exchangers, we want to consider the obvious design of putting the process stream in tubes above, and cooling water in tubes below, with the condensing fluid in the shell. The tubeside channels would be designed so that cooling water and process stay segregated.
I have seen seperate cooling water channels many times on surface condensers to allow online cleaning, but never seen service split between a process and utility stream as I envision.
Has anyone ever used two segregated fluids on the tubeside of a single exchanger in the manner I envision? It would save alot in capital, equipment weight, and space. I will take any opinion or comment.
best wishes always,
sshep
best wishes always,
sshep
RE: Two Tubeside Fluids in Shell and Tube Exchanger
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
rmw
