Urea Fertilizer
Urea Fertilizer
Urea Fertilizer
Is it an acceptable common practice to spread the urea fertilizer over the soil and formworks to avoid freezing the soil and rebars before pouring the concrete for grade beams and/or footings? Does ACI talk about this? Thanks in advance.
RE: Urea Fertilizer
Personally, I have never heard of this technique.  The ground never freezes long enough here for it to be of concern...
Where are you?
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
RE: Urea Fertilizer
I've not heard of using fertilizer and I don't see how it would function for anything more than a couple of inches.  In these environs, frost penetration is typically 6' and it definitely wouldn't work.
Dik
RE: Urea Fertilizer
Plus it will make your building smell like a cat box eventually
