Starting over with feeds&speeds
At this time we are now starting with NX7.5 CADCAM, giving us the opportunity to organise things better/new from the start. This should also include the definition of feeds and speeds. We are a die&mold company, machining mainly 1 [sometimess a second] type of partmaterial, with an average of 40 tools [same on 15 CNC-milling machines] using predefined operations in a template [up to NX7 at least]. Sometimes we need to switch a certain operation to another tool, and to reduce errors, we would like to make things like F/S automatic, depending on tool/part. What is the easiest and best way to do so, is it possible to attach a speed/feed to a tool or other parental object of an operation, or is it necessary to cover this with the machining-data-library? If it is the last, anyone a good tip/roadmap to setup properly? Or even using a third parties plugin to deal with it?
Thanks in advance,
Bert
Thanks in advance,
Bert
RE: Starting over with feeds&speeds
Bill
Can this only be done maybe in the postprocessor using a specific toolname or are there more options?
Bert
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
