100KW load
100KW load
Dear all for for 100KW load what kVA gerator can used? how to calculate and design emergency generator?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: 100KW load
That's like asking how do I design a house? It depends.
You need to know the type of load, power factor, inrush level and duration, etc. Most generator manufacturers have software to help you select the appropriate unit. It will ask you these questions.
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
RE: 100KW load
http://www.mygenerac.com/PublicPDFs/0172610SBY.pdf
Check CAT as well and you should figure it out. Most important thing is to consider motor starting.
