How to move the Assembly coordinate system
Hi all, can the assy coord sys be moved? If yes, how?
thanking you all
RE: How to move the Assembly coordinate system
Are you wanting to move the default (first CSO) or make another one in a different location?
If it is the first case:
You cannot.
If it is the second case, then you can make a new coordinate system using any of the available options.
Steve
http://www.3dlogix.com
thanx, this is unfortunately the first case
Well... you could perhaps just move the location of the assembled objects such that the CSO is where you would like it....
Daniel Pro/E Specialist
http://www.torgon.com/
How about rotate the CSO?
If you redefined the assembly parameters of the first part assembled you should be able to reorient the whole assembly in relastion to the ACSO.  This will include both rotation and translation. The best way to do this is probably through aligning and mating datums in the part to the assembly.  The program uses the CSO of any part or assembly as it's fixed point of reference, therefore you move the parts around it.
Dave
