Indium wire
Indium wire
Indium wire
I am looking to find some indium wire for our lens assembly. We have purchased some in the past but those records are long gone and the rep from our gas provider has not come up with anything promising. Is there anything that can be used instead of indium?
RE: Indium wire
We can supply you with In99.99 from.010" -.500" diameter ship today if needed.
RE: Indium wire
we make pure indium wire, foil & gaskets;  Can make wire of any diameter within 1 day.  call me at 401-429-5215.
RE: Indium wire
Indium Corporation has a long history of providing indium in every form including wire.  You can buy standard sizes on line at www.indium.com or call us directly.
RE: Indium wire
Don't be afraid to look on eBay for small quantities of Indium.  Although your indium suppliers will try to scare you off with horror stories (... and then the indium wire from eBay came alive and strangled him...), in reality there are some ex-industry guys on there who sell quality stuff at reasonable prices.  Just check feedback and ask questions.
RE: Indium wire
Hi,We have our own factory to process indium products such as indium foil, indium wire, indium ball, indium powder, indium target, ITO, etc.. The quality is high standard, and the price is very favorable. Our indium products have been exported to USA, UK, Germany, Holland, Japan, South Korea, Singapore, Taiwan, etc.. and the quality is well appreciated by our customers.
Indium wire is widely used to create high vacuum seals in cryogenic apparatus, 1.0mm diameter ideal for making seals where radial space is limited. We make a wide range of Indium wire diameters. One of the most requested sizes is 1.0mm, but our available range from 0.5mm to 3.0mm and larger.
Meanwhile, Indium foil is ideal for creating cryogenic vacuum seals. High quality Indium foil is available in many sizes, or they can be custom made to customers' requirements. Indium foil is supplied in sheet form.
For information about our products, you can visit our website at www.hanbillion.com
Email:tonyhantao[at]gmail.com
