How to form a partial funnel flat pattern?
How would you go about creating a flat pattern for a funnel with the top 2/3rds cut off? I know you to make one by rolling the sheetmetal and then "welding" the ends together but how would you do it for if you wanted to form it from a washer shape as the base material? In essence you are almost drawing the washer down into the partial funnel shape using a press. Is this something SolidWorks can even do?
RE: How to form a partial funnel flat pattern?
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Jeff Mirisola, CSWP
M9 Defense
My Blog
If you're attempting to make this part in-house, you would probably have more success with Spinning a washer shaped blank into a cone.
A deep drawn part would probably start with a solid blank (no hole) and have the ends sliced off after being drawn.
Lots of information here;
ht
You need BlankWorks, a third party tool to do that.
http://
StrykerTECH Engineering Staff
http://www.stryker-tech.com/
