CAM Post Process Trouble selecting WCS G code
Hello All,
I am working UGNX 7.5.2 windows XP pro 32 bit.
I am using the post builder and I am trying to get a post to select the correct Work Coordinate system G Code.
I think the default value is 0 then it has a command $mom_work_coordinate_number + 53.
I want to set it so that in my turning operations it selects between G54 and G55.  Actually all of G54-G59 would be good, but I can't even get it to select correctly now.
Any advice would be much appreciated.
Thanks.
RE: CAM Post Process Trouble selecting WCS G code
In your MCS interface are you clicking details and the putting 1-6 in the offset window?
Shags72,
Thank you, yes I am.  Using that G block and adding the offset I am able to get one of the Coordinate systems I need.
However, we use multiple bump stops and have a different WCS after each bump.
Does this mean I have to add multiple MCS spindles to get it to work properly?
Either that or use an insert but I don't really like using those. I would have to look further to see if there is another way of doing this on a lathe. Haven't done that before.
Thanks again for your help.  It is working with multiple MCS spindles, but I don't know if that is the best way to set it up.  I will keep playing with it.
No problem.
Buckshott00,
You are doing it correctly.
If you want a different offset, you make a unique MCS.
"Hard Coding" anything into the post is asking for trouble in the future, in my opinion.
J
NX 6.0.5.3
Thanks Jaydenn,
So if I have a millturn machine,Z=0 is the finished face of the turnpart. I want to use G54 for Turning and milling, G55 For Facing using a Front Stop, I would use 2 different MCS spindles.
Can I nest them and still get the desired results? I guess I am confused about and Z axis offset when it appears (for this part) that NX is compensating for the Z offset already.
Does that make sense?
That has always been how I handle things.
I make my workpiece the "parent" and as many MCS's as I need are the children.
GEOMETRY
--->WORKPIECE
         |---->MCS-G54
         |---->MCS-G55
         |---->MCS-G56
All of my mcs's are oriented exactly the same. The only difference is the fixture offset number.
Keep in mind that I don't typically program for a mill-turn, so there may be some other "better" way I am unaware of.
J
NX 6.0.5.3
Thanks again J,
That's how I ended up doing it.  The only thing I wasn't sure of was placement of the MCS's when adding new ones.  It seems odd to place a Machine Coordinate somewhere different to accommodate a work coordinate.
--Jake
Looking through the program, I lost my Z 0's on the face of the part but I think I can figure out how to fix it.  Thanks again guys
