Furnace uniformity survey - API 6A
Dear all,
I have the following question:
is there an annex in API 6A which gives guidelines on how to carry out heat treatment furnaces uniformity survey? (no. of termocouples to be used, their position, etc?).
If so, could you specify the exact reference in the code?
Thank you in advance for your precious help
BR
BR
RE: Furnace uniformity survey - API 6A
Specifically M.3, if you need exact.
rp
To which edition of API 6A do you refer to?
Marco
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
