nx cam hole mill
nx cam hole mill
nx cam hole mill
what geometry is hole mill looking for? i tried to create it and save under the workpice, but it will not show up and the select hole, top of surface and btm of surcace is greyed out.
Thanks, Damian
RE: nx cam hole mill
What software are you using?, then use the appropriate forum! There is a forum search field near where it says Search a forum.
