Automatically change dimension to set a parts mass?
Hi All,
I'm trying to model up a dynamics problem and I was wondering if it's possible to adjust a dimension with a mass goal in mind. So if I want the mass of the part to be 5kg, Solidworks will adjust a dimension I specify in order to hit that value.
In excel it's called goal seek I believe.
Thanks.
60% of the time, it works every time.
RE: Automatically change dimension to set a parts mass?
Sounds to me you should use a design table using the excel goal seek functionality.
You can add a lot of functionality to design tables, just skip a row below your dimensional parameters.
-DB
-Dustin
Professional Engineer
Pretty good with SolidWorks
Check out "Creating a Design Study" in the help.
Rob Stupplebeen
Thanks I'll check that out right now
A sensor will allow you to modify the driving dimensions and will alert you when you reach the critical value.
