Sour Service and Turbulent Flow Corrosion Issues
We are considering using a 'fingers' type slugcatcher designed to take dry gas into a first stage separator for multi phase well fluids. The product has around 12% H2s with about 4% CO2. The inlet geometry is very complex with different headers of various diameters from 10" to 28". The slugcatcher is carbon steel
I am particularly worried about pitting corrosion especially in the turbulent flow areas where inhibitors may not be very effective, has anyone experience of this type of flow and any suggestions regarding protection and or monitoring.
This is a temporary situation that may last 18 months, normal wall thicness is generally 15mm
RE: Sour Service and Turbulent Flow Corrosion Issues
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
