Power to drive R134 Freon compressor
Can someone estimate the power required to drive a modern, everyday automobile air conditioner compressor, R134, assuming a 90 degree F ambient temperature. Ball Park figures welcomed.
thanks
thanks
RE: Power to drive R134 Freon compressor
Mike Halloran
Pembroke Pines, FL, USA
steve
Given the 5" or so pulley sizes, that much HP can easily be transmitted by a single v-belt at the RPM involved.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Otherwise, it is a matter of doing some research to see if you can determine the "average" tonnage that your "everyday" car requires and then do the thermodynamic calculations along with some reasonable assumptions about compressor efficiency, etc.
That is my tip - I don't do math on this site (do that for my day job.)
rmw
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
rmw
5 hp is way more than the Sanden 508 takes from what the AC people say. A single 3/8 belt lasts forever if it is tensioned right and in alignment with the pulleys.
99 Dodge CTD dually.
That is, for the time it is actually running.
Note the comment about heating load of a typical car in winter below...
http://mac
Anyone have any experience with this system?
http://
http://www.sanden.com/index.php?tag=LZYYCH9G2
Not clear to me what the units on the left axis are...
Cheers
Greg Locock
