How to find Bad object in sketch buried in model
I am getting a error of "Invalid Face" that gives me the verbiage when updating object of type centerline in part(Name)
  The part is basically an extruded plate with a lot of holes.  I don't see anything wrong, sketch is green.
  Is there a way to search out the offending centerline in  the sketch/Model?
RE: How to find Bad object in sketch buried in model
This may be something that GTAC might be better equipped to track down for you.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
There is a very similar reference on GTAC. (PR-05970459) All it says is: For PR Data location please see the Coordinator Notepad  I see no other information that would be of help.  I search the PR number and get nothing but the same description of the problem.
Have you actually CALLED GTAC and asked them to look at your particular part file(s)?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Right click the sketch and select extrude.  If there is a problem with the sketch, UG will highlight it when selected this way.
