New Pump Connection
New Pump Connection
I have an Emergency Panel 480/277 V 3 Ph,4 Wire,60 HZ . It has in outgoing 3ph 4 wire breakers connected. I need to purchase a new de watering motor of 1 HP & to give power from this panel.
1. Can i connect 1 phase also from the outgoing 3 ph breakers.
2. The voltage for 1 phase is 277, so will 230 V 1 ph will be suitable.
thanks
thanks
RE: New Pump Connection
You other option will be to purchase a 480V:240V transformer and run a 230V single phase pump.
No, 277V is not quite the same as 240V. That;s why they call one 277V and the other one 240V.
Supply voltages are multiples of 120V.
Motor voltages are multiples of 115V.
Bill
"Why not the best?"
Jimmy Carter
Yes, the 460 V motor will be more expensive. Just deal with it.
David Castor
www.cvoes.com
